JoshHefnerX
I've scrolled through this a couple of times now, what was the starting weight of the stock machine?
The starting weight was basically a stock V5. The calculation took the lipo i was using at the time (CHNL) as well, so if we’ll remove the lipo from the equation, we’re looking at 256g of weight reduction compared to stockI've scrolled through this a couple of times now, what was the starting weight of the stock machine?
ThanksNice build. You drive well also.
This the final weight?Dry weight - w/o tires or body - compared to a friends TTLR with the same system:
View attachment 174770View attachment 174772
The 3s 4x4 could never compete against this on the track.Holy cow, that's a good saving! Food for thought, I know yours is minus wheels and body, but the 3s weighs in at 2.56kg stock iirc
Now that is a lean and mean Track machine there. Done really nice. The way a TLRT should be done.Dry weight - w/o tires or body - compared to a friends TTLR with the same system:
Since changed the car to a TTLR, which is a bit heavier (longer shocks, much bigger shock towers, mug guards and heavier wing).This the final weight?
What are you filling the car full of helium? You are always anti gravity lolSince changed the car to a TTLR, which is a bit heavier (longer shocks, much bigger shock towers, mug guards and heavier wing).
So final weight is 2,765g (no wheels, tires and body)
Looking back at this video made me cringe i improved so much since then.I've got a lot more details to cover which is didnt manage yet, so in the meantime some video of my practice yesterday. (pardon my son's filming skills)
Track was very dusty so not alot of grip.
My original link for the CVD's is no longer in stock, but they can still be found in europe:I bought set of Team Durango driveshafts for the DEX8 (which is if you don't know basically a Typhon), They are similar in size to the stock fronts but they are tapered and weigh less. I use them on the front and rear (as it comes on the DEX8)
