Traxxas toxic Stampede
Is this kit on the list? Its probably the rebuild kit? but Traxxas fail to mention the R ?
https://traxxas.com/products/parts/5352R
From link
Parts affected
5352XRebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (1)/ 2x9.8mm pin/ 5x8mm MW/ 5.0mm NL (1)/ 4.0mm NL (1))
5552XRebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (2)/ pin/ 4.0mm NL (1)/ 5.0mm NL (1))
6878Slipper clutch, complete (for Slash 4X4)
3695Transmission, complete (fits 1/10-scale 2WD Rustler®, Bandit®, Stampede®, Slash®)
4983Transmission, complete (fits T-Maxx® 3.3)
5491Transmission, complete (fits Revo® 3.3)
5691Transmission, complete (fits Summit (2-speed))
9495Pro Series Magnum 272R, Transmission, complete (assembled) (fits 1/10-scale 2WD Rustler®, Bandit®, Stampede®, Slash®)
5351XT-Maxx® Torque Control Slipper Upgrade Kit (fits first generation T-Maxx® transmission, w/o Optidrive®) (patent pending)
5352Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring/ 2x9.8mm pin/ 5x8mm MW/ 5.0mm NL)
5552Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring/ pin/ 4.0mm NL)
7152Slipper clutch, complete (includes slipper clutch hub, clutch pad, spring, 3.0mm NL, 1.5x6mm pin)
6766Gear clutch, complete (high stall)
7095Transmission, complete (fits 1/16-scale brushed models)
7096Transmission, complete (fits 1/16-scale VXL models)
5365Brake pad set (inner and outer calipers with bonded friction material)
5564Brake disc (semi-metallic material)
5417Brake kit (dual disc rear for Revo®) (Requires center differential kit, part 5414)
I have one of those diffs in my pumped out slash (now owned by my son). It's got about 2 years on it now and it works perfectly. I recommend it.
From link
Parts affected
That kit is not on the list because it has pads made from aluminum I would not recommend that kit BTW as aluminum is not a good material to use in a slipper clutch I mean it's aluminum on steel need I say more.
Thanks for the info when the slipper get bad i just buy the 6780 to replace it.
