Camaroboy383
Invention is the mother of necessity!
ArrmaForum Fan
Hospitality Award
- Connecticut
- 4x4-Mega
- Felony
- Outcast 4s
- Outcast 6s
- Outcast 8s
- Typhon 3s
- Typhon 6s
Ok.. put your front can bearing in.. then drop the rotor in slowly.. put your finger over the end of the can to catch the shaft and let it drop in slowly..
if you try to lower the rotor into the can without your finger over the shaft it will get sucked out of your fingers...possibly pinch you in the process and slam against the inner race.. (both bad) lol...
Then the following order...
Wavy washers one on the other.. the U shape facing down toward the front of the can... then the small spacer.. then install your end cap with the new bearing..
Use a tiny bit of blue loctite on the small m2 screws for the cap and gently snug them.. they strip and snap easily so be gentle..
Hope you get up and running man..
