Tuning Option: Spring Length
obessedwithrc
Military Veteran
San Diego, CA
  1. Fireteam
  2. Mojave EXB
  3. Outcast 4s
  4. Talion EXB
  5. Typhon 6s
  6. Typhon TLR
  7. Vorteks
  8. Infraction 4x4
Tuning with Spring Length
Hey fellow addicts. I'm working on tuning shocks for the Arrma Senton. I've watched a ton of YouTube videos on suspension tuning and of course, there is plenty of information on how to tune shocks by changing shock oils, pistons, hardness of the spring, etc.—but, I haven't found any resources, yet, on how to tune shocks by changing the length of a shock spring.
For example, how would handing characteristics change if I were to use a 53mm spring instead of a 45mm spring, given the spring rate of each was exactly the same and no other changes were made to the shock setup?
I figured out some more obvious stuff like that a longer shock spring (if it's too long) could limit compression if the spring is fully compressed before 100% of the uptravel on the shock is used, but I'm looking for deeper info on how spring length changes affect suspension performance.
Does anyone have a resource or two for this?
A longer spring is the same as adding spring spacers. No big change in spring rate, changed ride how high the rig sits. Too long effectively makes the spring a higher rate, but your better off going stiffer spring to retain adjust-ability.
Too short and you cannot adjust properly with spacers or the rig sits too low.
53mm is same as a 45mm with an 8mm spacer on the end.
