I had to order a battery tray for my Mojave to get them to fit.Do the turnigy graphene panther 5000mah 6s batteries fit the battery trays in the kraton and outcast? I ordered some and then realized they're slightly wider than the tray.
Always better to be safe rather than sorry, ...I did exactly that on my Typhon and added an extra strap.Whenever I remove the front plastic piece I replace it with a strap. To not do so is asking for trouble if you bash. Maybe it's ok for running up and down a street ?
They're great batteries.Well that's reassuring. I really didnt feel like returning them. I guess ill try taking that top plate off and see how it goes. If that doesn't work for me ill get the v2 tray.
I had one in the V4 Kraton. Its tight but worked great.
how's the tray holding up? i was looking to get the same battery for my kraton v4 but was concerned it might be too wide for the tray.
My Typhon 6s tray is 48mm wide, the Graphene Panther 5,000 mAh 6s pack is 49mm wide.Can somebody please give the me actual size of the 6s 5.0 Graphene Panther? Hobbyking says 145x51x61mm, but that can hardly be true, since you guys seem to be able to fit it into the stock tray, which is 45mm wide.
