Fireteam Turning my Fireteam into a FireBuggy
Gargantugorgon
Picked up a gently used Fireteam off FB Marketplace and I'd like to turn it into a buggy/truggy since Arrma doesn't make a buggy as large as I want. I plan on starting pretty simple since I'm new to the Arrma 6s system. I'm going to pick up a Limitless body and put a Kraton wing on it. Could anyone direct me towards the parts I need to swap to the Kraton body mounts/wing mount? I will have pics once I get a Limitless body fitted up.
Typhon/kraton wing mounts and wing. Rear body mounts for typhon/kraton. May need to drill new holes tobget the right height, or get the arrma body mount set for the adjustable posts.
Fronts a little harder, esp with the t2t brace that probably shouldnt be removed. An arrma body post will go into the front t2t mount and you can adjust height to go over the t2t brace.
May want the m6 mud guards to seal the body back up.
If you need the body post further back and have a 3d printer, let me know. Iv got a file for that.
Not the same, but a typhon chassis, mojave (same as fireteam?) shock towers. Fit t6 body over the t2t brace. Can see the 3d printed part in question.
The body will sit higher than a typhon due to t2t brace.
Thank you! From what I understand, the front body mount should be fine with the Limitless body, but I will need to use the Kraton body mounts that are further forward than the Fireteam in order to mount a Kraton wing. The parts I need seem to be:
ARAC3430 - Body Post Mount Set
81802 - RPM Wing Mount
ARAC9681 - Wing Mount Set
ARAC9652 - Wing
You may need the adjustable body posts unless the Fireteam already has them Arrma part ARAC3479. I added this to my Typhon to raise the body for 6s packs. I cut down one of the posts for the front. Heres some pics for reference, I assume the shock tower has same mounting holes.
Thank you, I'll check to see if the Fireteam has adjustable posts
