- Maryland
- Infraction
- Limitless
- Mojave EXB
- Senton 3s
- Talion
- Typhon 3s
- Vendetta
Here’s a few pics of my two vendetta cars I’m speed running with. I have continuing build threads in the speed demons category but will add updates here as well
The first one I ran this fall and managed 145mph before winter hit.
Setup is :
Mmx8s
Tp4050cm motor 3200kv
Killmode cap pack
Cnhl 5000mah 6s battery
Mod 1 gears 27/36
Metal diff and input gears,
Added custom carbon aero
Full custom carbon under tray
Bsr foam tires
17mm typhon 3s hexes
Limited shocks with droop screws and rubber line
Futaba 3pv remote with range extender.
The second one I haven’t run yet but is built from ground up:
Lwb chassis
Xlx2 custom carbon mount
Tp4070scm motor
Typhon wide arms/17mm hubs
Limitless rear shocks
Modified front shocks.
Emp battery trays
Custom mod 1 gears
Delta plastic full carbon body
Build 1:
Build 2:
Setup is :
Mmx8s
Killmode cap pack
Mod 1 gears 27/36
Bsr foam tires
Lwb chassis
Tp4070scm motor
Emp battery trays
Custom mod 1 gears
Build 1:
Build 2:
