Southernfury85
hello all I have a fury mega that I'm needing to replace the tx and rx on it and I'm just wondering what everyone else is running or had the best luck with. Thanks in advance
Note: This feature currently requires accessing the site using the built-in Safari browser.
I'm using Radiolink, lots of features and gyro built in if you need it.Around $40/50 online with rxhello all I have a fury mega that I'm needing to replace the tx and rx on it and I'm just wondering what everyone else is running or had the best luck with. Thanks in advance
There will be a little setup,binding to the tx,end point adjstment and center steering and throttle ,but you would have to do that with any rx/tx system.Will that be just a plug and play type of thing and will it work with the castle creations sct combo
