BrokeBoiRc
I want to do more stunts with my typhon 3s but I find the stock tires don't seem to have enough mass to flip that easily. Anyone have any good suggestions for bigger tires?
would I have to change the gearing with those so it doesn't get too hot? Or is stock gearing ok with those?MX28 Badlands, any of the Duratrax 2.8MT tires, or any other 2.8 MT tire with 17mm wheels.
Yes I would drop down in the 16-18T pinion range to keep the motor from overheating.would I have to change the gearing with those so it doesn't get too hot? Or is stock gearing ok with those?
ok thanksYes I would drop down in the 16-18T pinion range to keep the motor from overheating.
3.8MT tires are going to be hard to keep the front wheels on the ground. If you just want to do flips down the street, then OK. But if you want any semblance of a driving experience, 3.8” on the 3S rigs isn’t fun at all.I second what Jon said, any 3.8" MT with 17mm hexes is the ticket.
I had Duratrax Lockup MTs on my Typhon and they made flipping significantly easier. Those particular wheels/tires are 12mm so I ran an adapter and it didn't take long for one to strip a wheel. I wish they made that wheel/tire combo with a 17mm because they were amazing while they lasted.
Meant to type 2.8, I haven't run 3.8.3.8MT tires are going to be hard to keep the front wheels on the ground. If you just want to do flips down the street, then OK. But if you want any semblance of a driving experience, 3.8” on the 3S rigs isn’t fun at all.
Where did you find an adapter to fit 12mm wheels on 17mm hexes? I've been searching with no luck.I second what Jon said, any 2.8" MT with 17mm hexes is the ticket.
