bro.betterley
36/50I am building a Typhon from a brand new roller chassis, i have a hobby wing Max 10 120amp 3s/4s ESC, I also have 3s batteries. What motor and pinion would you recommend? I have also upgraded to metal slipper clutch gear.
I was considering a 3665 3800kv brushless motor and 20t pinion?
Thanks for all the input. Kind of new to all this. So I've been doing a lot of reading and playing, bought some wrong parts in the beginning. I'm going to be doing mostly open dirt bashing.
Can you give me one last opinion on pinions. If I was going to stay with a 3S setup close to factory, what pinion do you recommend? And if I was going to go with something closer to a 4S 2400 KV motor, what pinion would you recommend?
Either motor will be ran off My 3s 80C batteries
I have had good luck with surpass rocket motors, Hobbystar is good as well. Since you have a long wheelbase chassis you could put a 3670 or even a 4068 quite comfortably. If you’re going to strictly keep it on 3s, get a little bit higher KV, 2650-3100. If you want run it on 4s you’ll need a lower kv motor. Also keep in mind you’ll probably trash the drivetrain in stock form on 4s.Thanks for all the input. Kind of new to all this. So I've been doing a lot of reading and playing, bought some wrong parts in the beginning. I'm going to be doing mostly open dirt bashing.
RC Explained on YouTube has a lot of good videos. For example:Just trying to soak up the knowledge, not trying to split hairs
Will the stock heat sink (for the 36 size motor) actually work with the 4068 motor you linked?I have had good luck with surpass rocket motors, Hobbystar is good as well. Since you have a long wheelbase chassis you could put a 3670 or even a 4068 quite comfortably. If you’re going to strictly keep it on 3s, get a little bit higher KV, 2650-3100. If you want run it on 4s you’ll need a lower kv motor. Also keep in mind you’ll probably trash the drivetrain in stock form on 4s.
Both of these motors are smooth can, so they will work with the stock heat sink and fan. If you look at ribbed motors, those are made to work without heat sink using a fan mount and blowing directly on the motor. Either motor will push a 20t pinion easy. I like Robinson racing pinions mostly. Whatever you get it needs to be .08 mod with a 5mm bore. Good luck bud!
HobbyStar 3670 4-Pole Brushless Sensorless RC Boat Motor, Waterproof - 3050KV https://a.co/d/27cJ2cE
SURPASS HOBBY Waterproof 4068 2050KV 2650KV 1900KV 1700KV 1400KV Sensorless Brushless Motor for 1/8 RC Drift Racing Car Parts (4068-2650KV) https://a.co/d/dico4xH
Robinson Racing 8720 Hard 5Mm Bore(.8) Pinion 20T https://a.co/d/jiLdOOa
Good point and I don’t think so. I’ve never tried though.Anything larger than stock will be an improvement. The questions for you will be 1) how much of an improvement on power do you want, and 2) how much more power would you actually be able to use and put down to the ground.
The 3670 is generally a good balance between weight and power for the 3s sized trucks. The 4068 will be more weight than the 3670, but will have better torque and more surface area for heat dissipation. Once you decide on a motor can size, pick a KV that meets your gearing and tires setup to achieve the theoretical top speed you desire.
Dang, I thought you were on to something!Good point and I don’t think so. I’ve never tried though.
