Hi, my first post here and relatively new to RC world. Can someone help with some instructions on how to remove the motor in the Typhon 3S?
I removed the center driveshaft and screw that holds the battery strap. I can’t see anything else that holds the motor in. There is a tab which you seem to pull on, but the motor doesn’t seem to budge.
Was planning to change pinion/metal spur and motor mount.
