Yes u have to remove the 4 screws then. Go underneath the car and undo the arm thru the hole in the chassis just make sure your wheels are centered and power the Servo up so it goes to 12 o’clock then smack it in ..just a little tricky lining up the linkage and getting the bolt in …if u look at the pic you’ll see the hole in the chassis and the bolt u need to remove from steering linkage …My Typhon 3s was loosing steering randomly then it start grinding when turn right. I have new one. Do I have to remove the entire servo assembly to replace or will it pull out with the 4 screws
