Typhon Typhon 3s spur gear
ubhstry
  1. Mojave
  2. Outcast 6s
  3. Typhon 6s
  4. Typhon 3s
Does anyone have a link to a metal spur gear for the 3s slipper clutch? I obviously can not find one.....which seems odd??
Parts are listed right on the arrma website under optional parts when you select the model to view
https://www.arrma-rc.com/products/-/30/1/ARA102722/OPT/ALL/ALL
Never thought of that.....did not know they fit.?
Be careful to make sure you already have the castellated slipper pads that are required for the steel slipper. You will also need 4 pads now instead of 3. You may also need a different bearing too. Some say they found they needed a flanged bearing.
