A Max10 is too small for speed running in general. Do you have a Typhon 3S or 6S?I got a Typhon with a max 10 set up ive hit 67mph on 4s. But im runing stock spur with 18 pinion. Are there any other options to get it to maybe 70+ with out over heating. Should i unplug the temp wire? Suggestions plz
im running max10 set up 120amp but i only have thermal after 4 or 5 speed runs on 4s.. i don't have fan on motor i can try a motor fan but are there any other gearing options? im running stock spur 3s.. any time i look to buy i cant seem to find 1 that fits except integy for spurThermal is 221f. I can imagine you would push 221f. Maybe something else is going on. Esc fan working? possibly a bad bearing somewhere? What surface are you running?
I use these fans, they work great! Not very spendy, but move a lot of air. I'd say get a Robinson Racing 26T pinion, but give your esc and motor time to cool down inbetween passes.Any other suggestion for upgrade the max10.. An do u think the WTF are goid enough i see great review but don't kno any1 with em
