- Thread starter
- #121
As I mentioned before, back in the early 80s, I built and customized many RC cars for the hobby shop in Charlottesville and myselfThanks for the pointer on the trays I'll be watching for that.
I couldn't agree more. I enjoy the planning, research, and build more than anything. Often the results are less exciting than I build it up to be in my mind. Any time I go out and set a new personal best speed it is an extreme rush, but if I don't it is always very disappointing for me.
(as a hobby). As you know, those NiCad powered cars didn't offer many mechanical or electrical upgrades. Very unsophisticated, compared to this generation of RC cars! However, they were a blast to customize. My favorite was the Tamiya "Grasshopper". No lexan body. I built a (7) cell battery and put it into a Grasshopper that I set-up with steel bearings,dual wheels on the rear, and a proportional speed control, (very new upgrade at the time), it replaced the stock (3) speed forward and reverse unit, and a 540 motor. Sounds pretty lame now, but it was a big deal back then. I ran it once and sold it.
All of the detailed information that you,(and others on this forum), have been supplying me with, is so appreciated. It feels good to be back into my old hobby. Building and customizing Remote control cars.
Testing the car off of the ground. Makes perfect sense. When I get to that point, I'll do it. Is a signal booster basically an extended antenna?Now that you are getting closer to testing the car, be sure to test out the radio range on the car in that area with the car on the ground before running. I have had odd radio issues in certain locations where it will only go 200 ft due to interference. Then other areas where I would expect bad radio interference I can go 1200 ft beyond what I can see well.
I also learned that some of the higher end Futaba's with the FASST protocol have better range. Hopefully the 3PV serves you well. It has worked well for me so far, but I am also not going 150mph yet. Many guys run signal boosters that increase the wattage of the radio signal output. I can guide you on that if you get to that point.
Just be sure to have the receiver antenna extended vertically straight up and down the best you can and as high as it will go.
What steering servo and mount would you suggest?
