Pareo
I’m new here and in the hobby. I bought a typhon 6s for my son. He used yesterday and he said the has the center dog bone bent. Why this occurs? How can I change this shaft? Is the center to front one.
A likely suspect is that the chassis may have bent... causing the front drive shaft to bend. A good way to help prevent this is the aid of aluminum chassis braces. They go a long way to helping keep things straight. As for replacing it, the easiest way for me is to just pop the 4 screws off the center diff top plate and pop the diff out and both the front and rear shafts will be able to be pulled out.
hope this helps ??✌?And Welcome
The black plastic pieces on front and back. Check to see if ones broke.Thanks. Only the dog bone is bend.
Ok. Thanks. The dog bone at the center is the one is bend. But what is braces. ?
