rparkin986
- Kraton 6s
- Kraton 4s
- Outcast 4s
- Talion
- Typhon 3s
Can you put diffs from typhon in kraton or talion
They definitely aren’t the same. Look totally different.Yes. All the 6S diffs are the same.
U had me intrigued so I watched a YouTube video about it. I guess the Typhon is for some reason a little bit different. As long as you use the diff and the input together they will work though (according to the video I watched)They definitely aren’t the same. Look totally different.
Kraton diff i believe is spiral cut think olso the talion. but the typhon diff is straight cut gear i think the kraton and talion has a spiral cut gear coz its ment to be stronger but im no expert someone on here would know for shoreCan you put diffs from typhon in kraton or talion
No they are not. Spiral vs straight and different tooth count. If you put a Typhon diff in a Kraton, you need to change the input gear as well.Yes. All the 6S diffs are the same.
That’s what I was wondering. I bought the front and rear complete cases from Jenny’s for the typhon to put on my talion. Just wanted to know if anyone else has tried this. I heard you don’t have to shim and they are the same as the infraction and limitless as well so got to be durableNo they are not. Spiral vs straight and different tooth count. If you put a Typhon diff in a Kraton, you need to change the input gear as well.
They are more durable when using smaller and lighter tires. The stock Katars on the Talion might be fine as they are pretty light still. Just don’t expect straight cut gears to hold up long with big heavy tires. That’s why the trucks all use spiral cuts.That’s what I was wondering. I bought the front and rear complete cases from Jenny’s for the typhon to put on my talion. Just wanted to know if anyone else has tried this. I heard you don’t have to shim and they are the same as the infraction and limitless as well so got to be durable
