Kevinbosch711
- Typhon 6s
New bee here I have a new 6s running 6 lipo the front tires are ballooning pretty bad how can I fix this? Change the Differential?
huh? id need more explanation on this...front and rear diffs getting thicker fluid effects turning yes. but center diff?Center diff fluid 200k should be enough. Just remember when you thicken diff fluids(front and rear) it reduces your turning action. A thicker center diff fluid will give you good forward drive, but will be less forgiving.
i ended up changing the fluid. 500k and it stabalizes everything really well. acceleration is better and front tires aren balooning.
The center diff will mostly effect the drive, if you have a light center diff it tends to be forgiving over bumps, if it's thick you'll get good drive, but when it gets rough it will dart all over the place. Not an issue usually for bashing, plus the thicker fluids are a benefit in the air.huh? id need more explanation on this...front and rear diffs getting thicker fluid effects turning yes. but center diff?
It does effects turning - under power. when under power the weight transfer backwards so the fronts have less traction, on more open diff the power will bleed to the front, so the rear will push less, and instead the front will “pull” the car into the corner, but with a thick center diff the power don't bleed to the front, and so you just under-steer.huh? id need more explanation on this...front and rear diffs getting thicker fluid effects turning yes. but center diff?
only center. it'll take care of ballooning and it'll accelerate stronger. turning wont change, even under full load since the front wheels will be spinning closer to the speed of the moving car which means they will actually have some grip instead of just doing burnouts on the front. wheel spin means grip is reduced. which is why in real cars, people try to not have the wheels spinning on takeoff since that really reduces the acceleration due to no grip on the surface. same concept here. front wheels are spinning faster than the car, means they are basically just 2 donuts covered in soap just sliding about. you can steer them fully to one side, and the car will keep going straight. go ahead try it before you change the fluid. maybe in midair it'll have a different effect, but thats an area i haven't had the bravery to explore yet.You did all three or just the front ?
someone mentioned that it'll effect driving over rough terrain or bumps. that is accurate since right now, with the light fluid, whichever axel loses the grip, thats the axel that gets a sudden burst of power. i have no idea if thats desired in a race, but doesn't sound good to me.
shimming is needed because those internal parts in the diff spin pretty fast and from heat and friction eventually the oil leaks or the plastic wears away. when my diff fluid was changed, i noticed the diff was shimmed from the factory. maybe since mine is the latest model. but my differential was shimmed.Is it pretty basic to change the middle saw a YouTube video just worried about shimming?
@avogev, Well, I find it harder to accelerate while cornering with a stiff center diff, either the car “pushes” and understeers, or the rear accelerate so violently, it looses traction and overseers. With softer center diff the acceleration in the corners is so much for predictable.
And to clarify about the shimming, i’m wasn’t talking about the diff’s internal gears, but the input/ring gears of the diff (the gears on the outside). The front/rear diff will have twice the load if you put 500k in the center, as all the load of the car can be carried by the rear end when accelerating (or by the front end when breaking). With an open center diff, each end will be loaded only if the other end is having traction as well, meaning it’ll carry half the load only.
by that logic, cars that only have front and rear diffs should be failing twice as much. drivetrain load, i can understand, metal driveshafts should take care of those issues. but differential failure from a center diff being locked or absent alltogether, that i cant see. all it does is consistently deliver 50% power to the front and rear. i would even go as far as to argue that if the center diff oil is too light and the fronts lose grip and get 90% of the power, that would overheat and damage the front diff, bearings, dogbones (basically every front driveshaft component) alot more than a consistent 50% of a locked center diff.Yes, people need to be made aware of what they are doing and its possible effects. Thick centre diff oil absolutelywill be harder on the diffs and drivetrain but at least its not a fully locked centre diff that can easily cause diff problems especially with sudden sharp loadings after a jump for example.... where zero centre diff give due to 100% constant lock causes a huge instant shock to the drivetrain.
I've gone with 300k centre, I wouldnt go any higher and would probably be happy going down to 200k or even 100k for bumpy surfaces.
I know that drivetrain wear is likely to increase more than normal but quite comfortable with that and not expecting any explosions in my drivetrain anytime soon and I'm happy with not destroying my front tyres in one outing any more.
I thought 300k was quite a lot so 500k sounds a bit ambitious to me, be interesting to hear about drivetrain longevity over the long term from people who have done it.
No, locked diff transfer 50% to 100% of the torque, open diff transfer 0 to 50%.all it does is consistently deliver 50% power to the front and rear. i would even go as far as to argue that if the center diff oil is too light and the fronts lose grip and get 90% of the power, that would overheat and damage the front diff, bearings, dogbones (basically every front driveshaft component) alot more than a consistent 50% of a locked center diff.
Edit- Imagine landing front first off a jump with the throttle still pinned, lets say one tyre comes into contact with the ground first causing a sudden fast deceleration to its rotational energy to be transfered to both the other drive shaft and also the propshaft going to the centre diff. If the centre diff oil is really thick then far less energy can go in that direction and far more goes towards the driveshaft on the other side. That is the scenario I'd expect to see a gross overload of the front diff. Make sense?
Actually now that i think about it, one of the latest videos from RCsaylors on youtube. they have a truck and they run it under full load. the fronts balloon and one of the tires even blows up. if you think about it, theses scenarios are far more common because under full load, and a turn, one of the wheels lifts off the ground at some point. and if you have the throttle pinned, that wheel gets basically way more power than its supposed to take, (that differential also). that scenario is a good example why thicker center diff oil is good. maybe in some technical races where you rarely go full throttle thinner oil is useful but i just cant see it in other cases. but anyone is more than welcome to school me.
Damn.. Im reading a lot of 200k 300k 500k numbers..
For either a Talion, Notorious or a Outcast.. Wich come with 100k stock.. Well.. In that case its a raise of 200% to 500%
But the Typhon comes stock with just 10k.. So that makes it a raise of 2000% to 5000% !!!
