Bwelch1984
- Typhon 3s
I have the BLX120 2400kv combo out of the 4S rigs in mine and run on 4S. Can’t imagine needing anything more in this light of a vehicle.I run my 3s Typhon on 4s with the stock 3s motor and it absolutely rips!! only issues I have had are the driveshafts!
Every upgrade part I can get my hands on and it's almost ready to rollNeed help
Where did you get the blue wing and body? That thing is already the fastest 3S I’ve ever seen ?Almost done then time to go break some stuff.
Tbone for the front and I just painted the back.. hardest part is fitting everything in a tiny chassisWhere did you get the blue wing and body? That thing is already the fastest 3S I’ve ever seen ?
Ahh it’s painted. That cool. Looks nice.Tbone for the front and I just painted the back.. hardest part is fitting everything in a tiny chassis
It actually holds up fairly well to 6s, but 6s is just way too much power for these things for offroad use, there were guys running 6s on the Megas and they were only breaking the plastic output shaft for the slipper assembly and stripping stock spurs.Wouldnt go there if i were you.. Its gonna last only a single 6s pack.. If youre lucky!
Let me rephrase that..
The 3s rigs arent really made to handle any more than 3s.. If you put in a 4 to 6s setup.. Theres loads of trouble waiting to happen.. Stuff is gonna break prob every run.. Driveshafts, motormounts, spurgear..
I would have to cut the body and it would be scraping in the dirt everytime I flip it.. i was gonna just get a cooling fan maybe?I mounted a BLX185 on top of the receiver box in my Granite. That's where you should mount yours. I'm not sure about having the fan sucking in hot air off the motor with the way you have it. Just a suggestion.
HR just came out with some heavy duty axels and I'm running all metal for gears.. hopefully it will not break everything but either way i will have fun breaking stuff...I always do.. we race mostly ovals with about 20 to 30 buggys a race so I break stuff no matter what I run lolWouldnt go there if i were you.. Its gonna last only a single 6s pack.. If youre lucky!
