Typhon 6S New Motor.... Now what pinion to use?
Megafandrew
Alberta, Canada
  1. Talion
  2. Typhon 6s
I’m doing a little more modifying to my on going project Typhon 6S V4. I am installing a Castle 1515-2200KV motor and I’m pairing it with a Castle Mamba Monster 2. I am going to be running this buggy on 6S. Stock pinion is 14T for this buggy I believe. I was running a 16T pinion on the stock BLX185 setup with motor fans. I run a Power Hobby dual fan setup on the motor.
Can I safely get away with running a 16T pinion on this setup? Is there another pinion I should look at or go back to stock? Anyone with this setup? Thanks for any suggestions.
Well, you’ll be going up in KV a little so I’d start back with the 14, monitor temps, analyze speed and decide if it’s ok to go up.
Im running same setup typhon 6s 16t46 spur and 2 40mm r1 fans temp is good
Eb48.3 has same exact setup 1 fan but its faster then cause its really light this is my street basher ONLY
both rigs are fully upgraded from top 2 bottom
Tekno gets boca bearings $100 complete typhon fast eddy set ?
O nice setup on both. Well at least the Typhon got some rubber sealed bearings it deserved ?. Thanks for the information. I have a EB48.4 but I have a different setup. Trinity D8.5 2000kv motor 17T pinion/44T spur it goes good on 4S light weight like you mentioned makes a lot of difference! I might start at stock tooth and go up from there monitor the temps
ill do that, stock and go up as needed, it might be fast enough for where I run it with the uptick in KV. Thanks
I used to run a 2000 traxxas motor ? on 20t damn that was a rocket moror got dumb hot for street bashing 10 min day was over but had no fans just small esc fan
