After reading your reply to @lost247 I decided it's about time I finely invested in a better charger. Thanks!!Whether 100c or 60c discharge rate, this does not affect the physical dimensions of the lipo. Essentially the size based on the Mah capacity changes as the capacity goes higher. Best to use one single 6s brick IMHO. Although you can run 2x 3s if need be. I just don't feel it is as practical.
An underated charger will still charge a lipo, just takes longer. Better to invest in single 6s bricks. The priority IMHO. Unless you already have matching 3s packs and use them in other single 3s rigs also.
Need to buy the right packs and charger that will supply the correct amps for the chosen pack(s) capacity. You know this already.
I hope I understood your quetsion.
