Typhon Typhon 6s v4 fan motor
SlydeeRC
Hi guys,
Can anyone recommend a good motor cooling fan with mount for the stock motor for the Typhon 6s v4? (Ideally a UK based seller) I've had a look online but there's so many and I'm not sure which size I'd need!
Yeah go for the yeah racing dual fan setup. It's low profile to fit under the body and you can run it off the receiver. If you get a kraton/notcast you can run a 40x28 on a small 3s battery, and a talion will fit a yeah racing setup or a 50x20 on a hobbywing heat sink also powered off a 3s lipo.
I run this fan here which is basically an unbranded Yeah Racing one. But I replaced both fans with Hobbystar fans from RCjuice. The stock fans it came with had very brittle wire connections and broke just running on my street. So far since I replaced both fans its been solid and cool.
https://www.ebay.com/itm/New-Heat-S...d-Cooling-Fans-1-8-Motors-Colors/174426988570
https://www.ebay.com/itm/HobbyStar-...tor-Fan-Heatsink-5-0-to-8-4V-RED/173641288542
