- Vancouver, BC
- Granite
- Kraton 6s
- Senton 6s
- Typhon 6s
I'm trying to remove my wheel hex on my Typhon 6S in order to replace my bearings. Used a soldering iron on the grub screw, held it there for about a minute and then was able to break the loctite. However, the grub screw will keep spinning but will not loosen. It'll just turn either counterclockwise or clockwise but will not tighten or loosen. Any idea what may be causing this and how I may be able to fix it? Thanks.
