BlargBlarg
So I recently decided to restore my older gen 1 Typhon that I knew had a few issues. While tearing apart the rear diff I noticed that the rear input gear had snapped a couple of teeth off. Easy enough fix, I guessed.
Let's just order one.
I ordered Arrma part #AR310468. The exact same as the one listed in the manual, and I received the same.
The problem is that the new gear is the same 13 tooth count, but doesn't match up with the diff gear when reassembled. The new input gear is a bit smaller than the old one. Both of them are straight cut.
My question is, did they revise this and not change the part number? Should I order a new diff gear as well to match up with the new input gear?
