Chad08
So I made my own home built outcast with some extra parts laying around and ebay. I bought typhon bulkheads that were factory assembled with diffs, I did take them apart to shim and put heavier fluid in. After I put the car together it started making some grinding noise under hard acceleration. Well after 2 days of thinking this over and problem solving I figured out the problem. Apparently arrma uses a higher tooth count input gear in the bulkheads of the typhon and both front and rear ring gears stripped out. I can't for the life of me understand why that would happen. I understand I was using the wrong gearing but that should only increase top speed. Help me understand this hahah.
