- Dundee Michigan
- Infraction
- Kraton 6s
- Notorious
- Talion
- Typhon 6s
Big thanks to m2c for send me this to try out. And sorry bout sound.
YeS it is I was bending one ever time I took the typhon out for some reason. Put m2c shaft no problem.Seems like a success!
never bent them wonder what you do with them then ? and is it the same every time that is crooked?YeS it is I was bending one ever time I took the typhon out for some reason. Put m2c shaft no problem.
Only thing I can think of is chassis flex from hitting the ramp or landing. But I haven't had it happen since I put the m2ç shaft on it.never bent them wonder what you do with them then ? and is it the same every time that is crooked?
Nice man ur going love them.mine should be here tomorrow!!
Do you also have the M2C chassis? I replaced my front 116mm center dog bone with the stock one (the old one was bent) , and I aired out thig thing again and that front dog bone bent to crap AGAIN. I do 20ft plus jumps. Stock Chassis, M2C front and rear chassis braces. I also have the rear M2C shock tower. The front shock tower is bent to crap too.Only thing I can think of is chassis flex from hitting the ramp or landing. But I haven't had it happen since I put the m2ç shaft on it.
I've bent at least two with huge air. The last one I bent brand new after like 4 20ft plus jumps off a huge rampnever bent them wonder what you do with them then ? and is it the same every time that is crooked?
