Typhon Typhon mega 550 upgraded
crisH24
New Firma smart technology 85 Amp Brushless ESC , New 4000Kv Brushless motor installed. Motor mount with red mesh.
There is a frima 85 amp esc? Do you know what vehicle comes from?
It is aftermarket spectrum firma brushless 85 Amp ESC and 4000Kv brushless motor only works on arrma body's 1/8th scale and 1/10th scale
From rcplanet.com
Hello! I’m about to upgrade my sons Typhon 550 brushed to a brushless. I noticed this 4000kv firms as well a the 3300kv firms system. Do you recommend the 4000kv? Could you explain what other parts I should buy? I believe it’s the just the 3s slipper system and a 15t or 17t pinion? Any help would much be appreciated. Thank you!!
I'm looking to swap my brushed typhon to brushless. following to see all the questions/answers!
Spektrum esc and motor combo with a 5mm shaft . if you have a typhoon 4x4 550 mega will support a 540 as will get the blx steel spur gear 57T 0.8 mod slipper clutch and Assembly set with a 32pitch pinion gear .15-17 tooth pinion gear. No Higher. Lipo batteries are required for after market parts .
