JMega
I have a stock Typhon Mega that keeps overheating and cutting out. It's becoming quite irritating and ruining the fun for my kid and I. Sometimes we only get 5-7 mins of runtime before it shuts down. When it turns off, the ESC, motor and battery are all very hot.
I contacted Arrma support about it and they replied that I had a faulty ESC and shipped me a new one. When it arrived, I popped it in - and had the same result. No improvement at all. I emailed Arrma again, but after a few days I hadn't received a response other than the default "we received your message" auto-reply. I tried again and another three days have gone by without a response. ?
Enough with the customer-service gripe though - I'm looking for ideas to fix the problem. Here's what I came up with so far:
1. Gear it down with a smaller pinion
The Mega already isn't that fast, so I'm not super keen to lose more top speed, but I thought this would be the cheapest and easiest way to reduce the strain on the motor and ESC. Doesn't look like Arrma sells a smaller pinion for this car though. It comes with a 14t stock. I did find this set of three on Amazon, which contains a 13t, 14t, and 15t. I'm not sure how big of a difference one tooth would make though - or whether I'd need a different motor mount to use it.
2. Buy a different brushed motor
Not sure where to get one in Canada, but I presume I could buy another 550 brushed motor with more turns to get more torque and less speed? Still not a great option because of the lower top speed, but I could live with it if it was close.
3. Upgrade to brushless
I've read lots of threads about this. Sounds like most people say it's a bad investment and you should buy the 3s version instead, because you'll need to upgrade all the gears and clutch etc. I get it - but my current Mega is almost useless as-is and, unlike most, I'm not looking for a big speed and power upgrade. The stock performance is ok - I just want to be able to drive for more than a few minutes at a time.
So if I'm not looking for more speed, could I do a brushless conversion without all the extra drivetrain pieces? What about an ESC/motor combo like this? Would the 3650 3100kv version be pretty close to stock but run cooler?
Any other ideas I haven't thought of? Should I just get fans?
