Typhon typhon no throttle response
peyto2
New Member
help! just bought a typhon 6s blx v5 esc is blinking red (lvc mode). battery is a 6s 5000mah 50c and is fully charged 25.2v. servo and steering working just no throttle response
does steering work?? try disconnecting servo. trouble shoot it to determine is servo or ESC is the issue. May need to bind the TX/RX together even though
it says that it comes binded... ya never know..
yes steering works still and the car has ran fine since i bought it. ive tried unplugging the servo still no throttle. here how it started tho yesterday i was out running and stopped to check the motor temp as i just on new fans and wanted to see how well they were working and then the throttle was dead when i tried to go again
It sounds like what happened when I blew up my blx esc last time. Running one minute then blinking and no throttle the next. I was running it hard with a 19t pinion
