Typhon Typhon questions
WranglerBob
  1. Typhon 6s
So I'm new to RC as I said before so I got a couple questions with this Typhon I got. Got some jumping into it.
I noticed that my right front tire wobbles just a little and it was that way when it came. Also noticed that sometimes even after setting the steering trim to center, after running it a little and hitting some small jumps and a few bad landings, the steering will be off centered then. Any ideas what's up? I've seen others with the front right wheel having some slight wobble too but never got to checking out if there's a fix. I do have outcast hub components on order though so I can definitely get a good look at it all then.
Edit: oops this is 6S. Disregard my previous answer.
Not sure if you have the 3s or 6s models but A few bad landings is all it took to bend my steering rack like a banana on my 6s, leaving steering of centered. A quick pit stop to pull it out & gave it a hammering to straighten it - and back to normal. At the same time I orderd 2 new 7075 steering racks from GKA as it seems most others like voltage and just bash it are out of stock and didn’t want to be caught out again with my other 6s rigs. A very worthwhile upgrade if your bashing.
Yeah, my bad. I'm running a 6s model. I'll have to take a look and see if anything's tweaked. An adjustment on the radio helped but occasionally had to go back and forth on center. Bashing it pretty much 100%!
