James e music
- Notorious
I’m building a typhon speed run car I get tp 4070 2200kv does anyone know what esc would be the best for it. I can’t make my mind up between a castle xlx or max5.
Here is one way to do it. Only shows 1 of the parts needed, but gives you some directionDo know where to get those rear body mounts for the stretch typhon? I basically know they have to be built but not sure what to use.
https://www.rcracinginnovations.com...yphon_-Rear_Body_Mount_Special_Screw_Set.html
for reference to the OP the castle XL-X is the "best" speed run ESC to date. I don't know of any speed records that were set on other brand ESCs.
