I'm swapping chassis and the dogbones I ordered for kraton to accommodate lwb have a bigger ball end on them on 1 side... Do I need a different diff or are the dogbones wrong
You shouldn't need the rear kraton dog bones if you're just stretching your typhon. You will need the longer rear center driveshaft & the longer rear chassis brace. Also some 55mm standoffs & some all thread rods to mount the bodyI'm swapping chassis and the dogbones I ordered for kraton to accommodate lwb have a bigger ball end on them on 1 side... Do I need a different diff or are the dogbones wrong
I messed up and ordered axle shafts instead of driveshaft... I screwed upYou shouldn't need the rear kraton dog bones if you're just stretching your typhon. You will need the longer rear center driveshaft & the longer rear chassis brace. Also some 55mm standoffs & some all thread rods to mount the body
I think the rear driveshaft is 135mm, not sure how long the rear chassis brace is tho off the top of my head. Good luck, I love a stretched typhon!!!I messed up and ordered axle shafts instead of driveshaft... I screwed up
On the bright side, your talion uses the same dogbones so it's not a total loss. Now you have spares!I messed up and ordered axle shafts instead of driveshaft... I screwed up
All done minus the driveshaftI'm swapping chassis and the dogbones I ordered for kraton to accommodate lwb have a bigger ball end on them on 1 side... Do I need a different diff or are the dogbones wrong
