Hey guys what’s the best tool kit for the typhon?
thanks
thanks
MIP makes the best drivers. You will need 2.5mm, 2mm, 1.5mm, hex drivers. You can use pliers for the wheel nuts, but you will strip them out. The wheel nut is a 17mm nut, so any 17mm socket or spanner wrench thingy will do.Hey guys what’s the best tool kit for the typhon?
thanks
I wouldn’t mind a look at bothWhat are you looking for? Hex drivers only or a full set with box wrenches and stuff?
What he said. Mip makes the best drivers. I have been using these and they have been holding up great! I use it for pinions and everyday RC things! Nothing has stripped yet!MIP makes the best drivers. You will need 2.5mm, 2mm, 1.5mm, hex drivers. You can use pliers for the wheel nuts, but you will strip them out. The wheel nut is a 17mm nut, so any 17mm socket or spanner wrench thingy will do.
Here you go!I wouldn’t mind a look at both
If you have any links to products I would appreciate it
Yes. I use those, but I wish I got MIP from the beginning.
Here are the ones I got.
