I read a lot of posts where the left the stock shocks on the rear for speed runs. I looking for more on road handling, and speeds less then 80mph.Reduced suspension travel. Stiffer all around. Overall better suited for on-road / GT style running than the original Typhon suspension.
I have 2 more, one to paint up like the ricky bobby ME car and one to keep around for a spare when Curt cuts me a legit chassis for it. This one is a little weak. Had to take 47mm out in front of the diff.That body is badarse!
Def interested!!! What company makes the body?I 3-D printed some custom body mounts.. I'll get some pictures of them up tomorrow if you're interested.
Did you convert shock towers or were they straight off a limitless and fit straight on?It's all personal preference. Some people don't run shocks for speed running, some run with the front or rear locked out. I don't believe that will bode very well for you if you are interested in running a GT style Typhon conversion. And don't forget the aesthetic aspect!
Shameless photo op in 3..
View attachment 111346View attachment 111348View attachment 111349
This is good to know the rational behind running shorter shocks and tower - just the answer I was looking forWe use the shorter towers and shocks to lower the body height. If your body doesn’t need that, don’t bother.
