Kraton Cooperhead tires...there should hole somewhere if in the rim they are small and tiny.
On the videos i saw them they where around 2-3 mm2 so i would see them, i inspected the rims 3 times with flashlight, no holes at all.
Check your tires carefully. Some models now come with tires vented from the factory and no holes in the rims. Nice change by Arrma, I hope they roll that out to all off road rigs.how come my tires doesn't have the inside holes? Exb?
My Copperhead 2 Kraton 6s RTR wheels came with Vents on the wheel, I taped them off and put 2 holes at the tread. Look at the center tread closely. Arrma is starting to vent at the tread with some of their tires now. The holes are small at the tread. Hard to see them. But adequate. There must be vents somewhere inside the wheel or at tread.Kraton exb?
No holes on the inside rim not sure for the tires threads
Is yours an 8s CH2? Which tire ?
Seal them inside, vent them outside.
If you don't seal them inside and get dirt / water inside they get heavily unbalanced. No way to fix that. You will have to replace them.
If there are no holes on the inside of the rim you have one less task to complete. To vent the tires you need a very high speed tool like a dremel or a sharpened tube.Where inside? my tires doesn't have the rim holes as stated before. Thanks.
The newer tires don't have the holes and are already vented.
With no venting they may be bouncier. It’s all good unless the glue starts to go on your tires and you get gunk in there. I would check before each run and touch up the glue as needed so you don’t get stuff in there.DO I NEED to vent them if there are no holes on the rims? my goal is to be able to drive in dump condition's without worrying, i prefer to not vent the tires if thats better to AVOID gettting them wet from the inside?
So what do i need to do?
So I need to check the sides of the tires to see if the glue is going off, is there a visual representation?With no venting they may be bouncier. It’s all good unless the glue starts to go on your tires and you get gunk in there. I would check before each run and touch up the glue as needed so you don’t get stuff in there.
It's both a visual and manual check. You should always push/pull on the tires to make sure the tire bead is securely glued to the rim. If you pull on the tire and the tire comes away from the rim a bit, you need to run a little superglue and glue it up tight before you run it. If you check and notice a spot where the glue has come loose, pull all 4 wheels off of the rig and check all around both side of all 4 wheels and add glue where needed.So I need to check the sides of the tires to see if the glue is going off, is there a visual representation?
