stephen
- BigRock 4x4
The other day I was in the rain, and the stocks tires would unload in the corners. Well of course I kept the throttle pinned. One wheel flew off, I thought I didnt tighten it, but it was the whole stub axle along with the bearings that ejected
The little screw was still captured in the u-joint, came out of the stub. You can access this if you have a very long allen tip. But I didnt. Little heat from a heat gun allowed me to pry out the metal ujoint, and red loctite the screw back in the stub axle. You don't need much heat, just enough to gently pry out the joint
Hope this helps for folks that don't have that extra long allen driver.
