Nope, comes with a program box made it easy.Nice! Was it difficult to program?
i just ordered it today...does it bolt right in or did you have to do something to make it fit?
it doesn't bolt in you will double side tape it in with the tape provided.i just ordered it today...does it bolt right in or did you have to do something to make it fit?
K cool thanks man, let me know if there is anything else I should know about setting it upit doesn't bolt in you will double side tape it in with the tape provided.
The only modification I had to do was to grind the lip off the servo mount tray with a dremel, took 2 minutes.
good idea!Nope, comes with a program box made it easy.
Also shimmed all the diffs and put 50k/100k/10k in makes a huge difference wheelies on demand.
Swapped rear springs for Tekno Orange and moved my stock rear springs to the front.
I don't really understand what your asking. The only wiring thing to do was sotter the connectors ( female) so the esc can connect to the motor. Everything else was plug and play. I like the esc. No more shutdownsI got a question did you wire i. The cap or just left it out. I just got a max8 and i don't want to ruin 8t like i did the hobbywing xerun 150a
Mine came with a cap that they said if the rc weight over 7 kg to solider it inI don't really understand what your asking. The only wiring thing to do was sotter the connectors ( female) so the ESC can connect to the motor. Everything else was plug and play. I like the ESC. No more shutdowns
