Caffeine
My servo started acting up.. dead spot. not sure how I killed it.. anyways.. I had a old metal gear servo so I swapped it in. it's a little slower then stock but it should keep me rolling.
so the bigger upgrade was the 10T motor. I put it in, it's very very easy to swap motors! so it was a short run on li-ion.. the motor and ESC where fine barley any heat at all
speed was up but not by much- I need to try a Li-Po!
after looking up specs of the 18650's, the specifications say 5 amps max so even 6 In parallel (3 x 3) means a max of 15amps MAX.. for some reason the battery plug was hot. much hotter then anything else.. not in danger mode. but not where I expected to find heat.
So here is the setup.
Servo LINK -https://www.banggood.com/TowerPro-MG996R-Metal-Gear-Digital-High-Torque-Servo-55g-p-982287.html?rmmds=search&cur_warehouse=CN
10T Motor LINK = https://www.asiatees.com/display?id=84062&brand=Miscellaneous&model=All
