Do you have a link on the newer 6 mm version?Which stock? theres the old version which is 5mm thick, but lately they start shipping a new 6mm version which is stronger. If you have the old one ide suggest first trying the thicker version.
The hot racing is same (or even weaker) than the old 5mm plate.
If you want real stronger, them M2C.
https://www.amainhobbies.com/arrma-mega-3s-blx-aluminum-motor-mount-set-ara311106/p1330036Do you have a link on the newer 6 mm version?
Actually, I have the M2C motor mount plate. The M2C motor mount plate itself is great and stays straight without the brace. In my opinion, the brace adds nothing but drawbacks. It adds LOTS of weight and expense. But worst of all I think it creates a problem. By stiffening the middle of the chassis, the rear is forced to flex even more. I think it increases the chance of damage to the rear diff/input gear/slipper. I heard you can request just the motor mount plate without the chassis block. If possible, I recommend ditching the chassis block.The M2C part is likely to be stronger with the additional brace,
If the KC-RC works well, there's no need for an additional brace. Custom RC Upgrades also offers a 7075 motor mount for those in the UK/EU. So far. I've heard good things about the new 6mm Arrma motor plate, but I haven't tried it. The Hot Racing plate is not an upgrade, don't bother.
