Upgrade to brushless
Will1301
Hi
Is it possible to upgrade my senton to brushless? If so what would you guys recommend and what’s involved? Thanks
It also depends on what you personal preference is…as I made my mega senton into basically the 3s blx version using parts from Jenny’s
I don’t have a preference yet mate… it’s all quite new to me, but throughly enjoying it and would like to go brushless 😎👍🏼
That’s
what it’s all about…search around the Forum & keep asking the questions, the answers will be found here or someone will point u in right direction 😎
Im gonig to do this upgrade too. Biggest question is esc and reciever are a single unit. Can i still use the receiver and my transmitter with a new motor and esc or do i need to get all new electronics and transmitter?
You can use what you have now..or upgrade your transmitter and receiver.
No you can't. The 2 in one esc is brushed only and the transmitter only works with the 2 in 1 unit.
I need a new esc though, right?
You will need all new electronics other than the servo but I would highly recommend that you upgrade that as well.
Ok, that makes sense. I saw you can run a different reciever with the 2 in 1 unit but didnt see how to run a different esc. I assume i can pair my current transmitter to a new receiver easily if i run spektrum electronics. Or is there an issue with that too.
Oh I did not know that. I thought the receiver and the transmitter would work on a brushless motor and ESC..thanks for pointing that out. @slick2500 👍
I am pretty sure you cannot run a different receiver with the 2 in 1 unit, if you can that would be a first from any 2 in 1 unit. The transmitter will only work with SLT receivers such as the Spektrum SLR300, Tactic TR325 or Tactic TR326. As far as motor and esc go they do not have to be Spektrum you can go with any brand you want but I would get something with at least 100 amps and a 3660 sized brushless motor in the 3000-3300kv range, the eBay cheapo motors work very well considering what they cost, the eBay cheapo Surpass/Rocket/Allstar Racing whatever name they are going by this month escs are notorious for being junk so I would avoid those.
That being said the stock 3s motor and esc work great https://jennysrc.com/products/arrma...-typhon-ara4303v3?_pos=1&_sid=ee9968c00&_ss=r
https://jennysrc.com/collections/ar...brushless-3200kv-3660-4-pole-granite-ar102711
You will also need to source a 5mm shaft 48p pinion as your current pinion is a 1/8" shaft.
This motor will allow you to keep your stock pinion https://www.ebay.com/itm/1753693989...hDTta1QM+Y45k5xOEgPT67bVQ=|tkp:Bk9SR5jyh5XFYQ
Nah he has the Boost with this thing https://www.arrma-rc.com/en/product/40-amp-brushed-2-in-1-esc-and-slt-receiver/SPMXSE2140RX.html and I was wrong the stock transmitter can be used with other SLT receivers.
This motor will allow you to keep your stock pinion https://www.ebay.com/itm/175369398955?hash=item28d4d4aaab:g:D20AAOSwUoNi52lJ&amdata=enc:AQAHAAAAoKE4SX4DSCCjHs0rR/8a9Kn7yNdUQv9iVTZcj0y1AZpnRpwNkSFbQ8Ai3fqqGTZtTRINL5iwbV2UNO8N7L2kvrlrFNVfwF6StA4Pe5yUI8bCchL8BZb/Akg1GG9JXPPiLweKuiBV/oZ10cSxYoJy4Xh02Y0ymrP12S7GyIqYp22m322sqOyNULbsELs2g4hDTta1QM+Y45k5xOEgPT67bVQ=|tkp:Bk9SR5jyh5XFYQ
Ok so he can use the same transmitter but not the same receiver ?
Nvm got it.👍
Nvm got it.👍
Yeah, surprisingly they made the transmitter SLT compatible instead of it being tied to the 2 in 1 esc like pretty much every 2 in 1 esc made.
Get the BLX100 esc and either the Spektrum motor or the other one I listed above.
