Upgraded X maxx diffs
ross_jsy
Jersey, Channel Islands
  1. Granite Mega
  2. Outcast 6s
  3. Talion
Hi guys
My X Maxx has just stripped its rear diff and I am only a handful of packs after putting an 1100kv in it. Not really wanting this to be a regular occurrence so wondering if anyone has some tried and tested upgrades for the diffs?
I see Vitavon do a hardened steel ring and pinion set that is rather expensive but if it is bulletproof I'd go or it. Welcome to any other suggestions.
Cheers
Ross
Moirae
Beauty & Beast
Rig of the Month Winner
  1. Felony
  2. Fireteam
  3. Infraction
  4. Limitless
  5. Kraton 8S
  6. Kraton EXB
  7. Kraton 4s
  8. Mojave EXB
  9. Notorious
  10. Outcast 8s
  11. Outcast EXB
  12. Talion EXB
  13. Typhon 3s
  14. Typhon 6s
  15. Typhon TLR
I heard the Hot racing diffs are good. You must have landed on throttle pretty good though lol. I have a TP 5670 in my XRT and I've not killed a diff yet.
DLK83
$dirty hands-no money$
SE MICHIGAN
  2. Infraction
  3. Outcast 4s
  4. Typhon 3s
  5. Typhon 6s
The aluminum diff covers are a must on the Xmaxx imo, the aluminum diff cups help too but the covers are a must... Hot Racing or Vitavon, doesn't matter.. I wouldn't spend money on "hardened" gears unless you do covers and cups and are still having a problem. And even then, like Moirae said, landing on throttle will do it every time on the big trucks
ross_jsy
  1. Granite Mega
  2. Outcast 6s
  3. Talion
This is why I am wondering if I am over reacting and just to stick a standard diff in as I see loads with big motors in with no issues.
Zero landings on throttle, it has been jumped a total of I think 3 times before the last ESC mount broke and cut the RX wire, and they weren't anything crazy. Just hard sand and field runs for the remaining couple of packs, no standing back flips, nada. I first noticed what I thought was a click last night whilst braking.
Armarookie43
San Antonio TX
  1. Felony
  2. Granite
  3. Infraction
  4. Kraton 8S
  5. Mojave EXB
  6. Outcast 8s
  7. Typhon 6s
Hi guys
Cheers
Ross
I put the aluminum diff cases from the Xmaxx in the front and rear diffs, I put a shim in front of the output drives, and I put aluminum diff covers. No more issues. Don't forget the drive cup sleeves too. Check out my profile. I have a build threat for my X-Maxx for further detalls 👍
ross_jsy
  1. Granite Mega
  2. Outcast 6s
  3. Talion
I put the aluminum diff cases from the Xmaxx in the front and rear diffs, I put a shim in front of the output drives, and I put aluminum diff covers. No more issues. Didn't forget the drive cup sleeves too. Check out my profile. I have a build threat for my X-Maxx for further detalls 👍
Cheers I'll give the Ali diff cases a go first.
I actually discovered the missing teeth whilst pulling out the diffs to install the diff cups funnily enough. Put it back together and all I could hear was Kevin Talbot's "it's really getting it now" and sent it off properly lol
Dan2022
Another huge thing is the upper and lower bulkhead having a tight fit and no damaged threads. I'm running H.W. 800kv combo, and have went full circle now. I use stock HD gears, shim behind the pinion. Also an aluminum cup with an extra shim behind the side gears. I did not have good luck with the vitavon gears. They never broke, but did wear out fast, like not properly heat treated. I beat on my truck pretty severely, and they were done before 20 packs. It was nice having the punch turned up for a little bit.
RcDad23
Usa
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton EXB
  5. Mojave EXB
  6. Notorious
  7. Outcast 8s
  8. Senton 3s
  9. Typhon 3s
  10. Typhon 6s
Hi guys
Cheers
Ross
So here we go,sold my Xmaxx 5 days ago,back to stock because all m2c HR parts and vitavon ring and pinion and rear diff never happy,installed a 1250kv and even that one whit a 23t strip the gear and just in case I change bulkhead, HR everything and when I when back to stock was good but didn't want to take the chance on her again.so if that help just upgrade a few things but no,no,no more power,max 5 whit stock engine is enough.hope u have fun.
