Skithepow38
- BigRock 4x4
So I noticed my turnbuckles and steering links are wearing out and getting sloppy so was thing about upgrading to the Typhon 3s A arms. I also already have 10mm wheel extension on it. I know I need to replace the turnbuckles and steering links to a longer size. Is there a good metal/aluminum version with metal pivot balls available that won’t wear out that anybody can suggest? Also, should I change out my stock shocks with this conversion, if so what would you suggest including all parts and pieces to make it fit properly? Part number would be much appropriated. Thanks
While I’m picking your brains, what diff fluid should you recommend using in the brcc? Also does anybody have any suggestions for a fan set up for the motor?
Sorry for all the questions, just figured I would get them all out in one thread. Thanks again
