Granite Upgrading the Boost
Jeckler
  3. Typhon Grom
  4. Vorteks
The Boost I bought on sale a couple weeks ago has now been almost fully upgraded. Front diff, Typhon arms, links and wingmount, wheelie bar and 4s Outcast wing. Powered by a HobbyWing MAX10 g2 140a and 3665g3 3200kv motor on 3S running through a BLX motor module and 4S slipper. Sooo smooth. I'll be changing connectors to XT90 shortly. I'm still using the SLT2 transmitter with an SLR300 rx. Servo is a 45kg Amazon special at 7.4v.
I already ripped out a shock end, so have a set of HR bodies, threaded shafts and spring perch set in the mail. I noticed the rear diff is either already tight, or was tight out of the box, so 2 4S diffs and inputs and an HR yoke (for the rear) are on the way too.
GraTypCast
Good looking granite! Bash proud!
I put a MAX10 G2 2400 Kv in a Drag Slash for 4s w/ Mod1 and I love it. I am planning to upgrade my Vendetta, Slash Ultimate, Rustler, and my other 2 Drag Slashes with a mix of the 2400, 3100, and 4000 Kv Max10 G2 Combos.
I'm curious, did you get around to try max10 with 3100kv(?) motor in the vendetta?
