UpliFT-RC - v3 KRATON 6s Monster Truck Build Log
Uplift-RC
TB RC Bashers
TAMPA, FL 🇺🇸
  2. Infraction
  3. Kraton 6s
  4. Notorious
  5. Typhon 3s
Hi Guys, this is my first RC build log so bare with me! Here are all of the upgrades that I have installed on my 2018 ARRMA v3 6s KRATON Monster Truck so far that up to date.
T-Bone Racing
TBR - Rear Basher Bumper
TBR - Rear Flat A-Arms Skid Plates
TBR - Front Thrasher Bumper -
TBR- Rear Mud Guards
TBR - 6s Wheelie Bar
Just Bash It:
6mm Thick 7075-T651 Aluminum Shock Tower Rear (6oz)
1 Set of 4 Stainless steel 17MM Spike nuts (2oz) Installed
CRCU-AR-564 RR Hinge Pin Holder Arrma 6s
M2C RACING:
m2c 3005 ARRMA GOLIATH OUTCAST,TYPHON,SENT.,NOTOR. 6S BLX
m2c 3075 ARRMA 16 MM ZRS SHOCK CAPS AND ORING SHOCK PISTONS
m2c 3080 ARRMA SHOCK TOWER STAND OFF KIT
m2c 3055 ARRMA PILLAR BALL RETAINER NUT KIT
m2c 3076 ARRMA , KRATON,TALION, OUTCAST(SERIES) SHOCK CAP BUSHING
m2c 3102 ARRMA KRATON, OUTCAST, NOTORIOUS FRONT SHOCK TOWER
RPM Racing Products:
Front Upper & Lower A-arms for 6S versions
Mud Guards for RPM Kraton, Talion & Outcast Rear A-arms
Voltage Hobbies:
Servo Mount & Servo Clamps (Installed)
Front and Rear Skid Plates (Installed)
ARRMA PARTS
ARRMA KRATON RED BODY SHELL
ARMMA Red Aluminum Button Red bolts for (WING)
ARRMA V4 KRATON CENTER BRACE V4 Chassis Brace
SPRINGS:
Tekno TKR6083 shock springs rear - 1.6 x9.0t, 90mm Orange, 4.80 Lb/IN
Tekno TKR6093 shock springs front - 1.6 x 7.5t, 80mm orange, 6.11 LB/IN
TIRES
Dboots - Backflips
ProLine - Trenchers off-road tires
SRC: All Terrain Belted Tires
Bearings:
Jims Bearings
Servo Upgrade:
PowerHD- DW25L
Fans:
Yeah Racing Black 1/8 Aluminum Motor Heat Sink W/ Dual Cooling Fans YA-0261BK
Just Bast it - 6mm Thick 7075-T651 Aluminum Shock Tower Set
Voltage Hobbies Servo Mount & Servo Clamps
ARRMA V4 KRATON CENTER BRACE V4 T2T
17mm Spike wheel nuts from Just Bash it
ProLine Trenchers off-road tires
TBR Back Bumper Thraseher
** Like me on Facebook or you can follow me on Twitter **
Facebook Page: https://www.facebook.com/Uplift-RC-23...
Twitter Account: https://twitter.com/RcUplif
Mc2 chassis will do the upgrade when I tweak my stock one since I have around $800.00 tied up into my v3 already!
Hurry up and join the 1K club! ?
I don't know about you all but when I have done a lot of bashing and I have had my tires let loose on me before in the past. Check it out, i picked up some new Hot Racing 17mm Serrated Dirt Shield Closed Wheel Nuts for my 6s #KRATON.
FEATURES:
  • CNC machined 6061-T6 aluminum, anodized black
  • Laser engraved HR logo
  • Rubber o-ring Friction provides sure grip
  • Capped nuts protects stub axles from dirt and protects axle ends from damage when scuffed against objects
SPECIFICATIONS:
  • Hex size: 17mm
  • Height: 7.5mm
FEATURES:
SPECIFICATIONS:
  • Hex size: 17mm
  • Height: 7.5mm
I've lost one of these too. One drop, no more, of blue loctite on the outer thread of the hub each time you have them off. That will stop the loosening and loss of the nut. I killed three wheels before I started doing this. Too much loctite and you'll have a swear fest trying to get them off. Answer is "experience"?
I feel ya, I put to much of loctite on my collect on my prop and I could not get the shaft off for at least 1 hr lol... Finally i was able to get my prop off my #Sonicwake 36 inch Speed boat..lol
bicketybam, @WoodiE , @Notorious J, arrmadillo, As we all know the stock servo that came with my #ARRMA v3 are not the best in my opinion so I got the - POWER HD DW-25LV Coreless Motor 347.2 oz / .11 Titanium Gear Digital Servo...
What i really like about this Servo is the specs:
Torque(4.8V): 21.0 kg-cm (291.6 oz/in)
Torque(6.0V): 25.0 kg-cm (347.2 oz/in)
Speed: 0.13 sec (4.8V) │ 0.11 sec (6.0V)
Operating Voltage:4.8 ~ 6.0 DC Volts
Weight: 80.0 g (2.8 oz)
Bearing Type:Ball Bearing x 2
Motor Type:Coreless Motor
Gear Type:Titanium & Steel
Operating Temperature:-20℃~60℃
Working frequence:1520μs / 333hz
Size:40.0 x 20.0 x 38.8 mm ( 1.57 x 0.79 x 1.53 in)
Good buy. Be sure to set your end points so you don't overload the servo. Not gonna explain, search the forum and you'll find it mentioned many times. Now go bash and come back with a great story of backflips, front flips and huge air!
Yes sir, thats the plan!! Ones I get it installed I will do a small review vs the #ARRMA Stock Servo and the differences. Also, thanks for the update on setting my end points, its GREATLY appercaited (y)(y)
After going back and forth with a different off road tires. I wanted either the Dbotts #Copperheads or the Dboots #backflips!
After talking to a lot of #Arrma bashers, THEY said they liked the backflips the best for the for a 6s rig! They will not ballon as much as the copperhead will! Also, I should have my T-BONE Racing red front Thrasher bumper installed! More Pictures to come!!
No but its better then any other bumper on the market in my opinion.. Its saved my rig a few times. Cant wait to put on my red front Thrasher bumper to match up with my body!
Gotta agree to disagree then. My RPM has been indestructible, where I went through half a dozen T Bones in the same amount of tine.
