ridgehead44
- Granite
Thank you!PETG is rather brittle IMO. PLA or a nylon based filament might be good.
How did you attach it?I added a little plate from another steering cover I found on Thingiverse to help keep some crap out of the chassis
Have you figured out how to keep rocks from entering the front? Near the steering rods.I just glued the two pieces together
I got the block off plate from this model: https://www.thingiverse.com/thing:4620230
How well do the Typhon 3s A-arms hold up with PLA?Ender 3 V2 is one of the best bang for your buck out of the box printers you can get right now. My printer is the previous generation ender 3 pro so the V2 is the next generation version and has with many of the better upgrades I've done already included such as glass bed and silent motor drivers. It comes mostly assembled and the ender series printers have a ton of community support behind them.
I’ve used PLA+ for arms while waiting for “real” replacements. 100% infill. Haven’t broken a single one though I haven’t used them for long.How well do the Typhon 3s A-arms hold up with PLA?
Agreed. Ive tried a pair off thingiverse too. For me they held up for use as a buggy but at the BMX track one bad landing broke one. I think they are good for a backup set and keep a pair in the backpack I take out with me.I’ve used PLA+ for arms while waiting for “real” replacements. 100% infill. Haven’t broken a single one though I haven’t used them for long.
There are a couple options on thingiverse. They’re pretty good but not perfect.
He doesn't come around anymore.@suchtragedy
Just wanted to say thanks for sharing your work.
Printed the Max6 mount and it fits great!!
Thanks again!!!
Say what?!?!He doesn't come around anymore.
March 13,2021 was his last log in on all his different groups he was in. Idk I miss himSay what?!?!
Nice. What material?
That's great. I figured someone had made something like this. I just cut some foam blocks to keep the rocks out. will the Mega steering and driveshaft covers fit the senton 3s BLX? I assume so but wasn't sure if there was a design change. TIAHey guys,
I just wanted to link some of the recent designs I've uploaded to Thingiverse that some of you may find useful. Enjoy at your leisure. I'll update the original post on this thread in the future with new designs as I publish them. To view my full collection of these and other parts not listed here visit my Thingiverse profile: https://www.thingiverse.com/suchtragedy/designs
Just Added:
Arrma 4x4 Driveshaft & Steering Crank Cover Set:
https://www.thingiverse.com/thing:4654772
This cover set is designed to keep larger rocks/debris that fall in from the top and get caught in the center driveshaft or steering crank for Arrma 4x4 vehicles (Mega/3s/4s) with two options to pick from to accommodate both the short wheel base (SWB) and long wheel base (LWB) chassis.
Arrma 6s Stuff:
Spektrum Firma ESC power switch mount for Arrma 6s off-road vehiclesA Spektrum Firma esc power switch mount for the 6s Kraton/Notorious/Outcast/Mojave/Senton, securing the switch to the center roll cage. Shoutout to @Engineer who hit me up about creating a design for the Spektrum switch and for doing all the field testing of all the versions I made until it was good to release.Hobbywing push-button power switch mount for Arrma 6s off-road vehiclesThis mount secures the power button to the side of the Arrma roll cage/center roof support used in the 6s Kraton/Notorious/Outcast/Mojave/Senton. Hobbywing Max6 ESC mount for Arrma 6s off-road vehiclesThe mount/adapter plate allows you to shoehorn a Max6 into the offroad Arrma 6s vehicles using the 4 mounting screw holes on the bottom of the ESC, and then screwing the mount to the stock Arrma 6s esc mounting tray via predrilled holes in the tray. This is intended for people who want to install the Max6 without having to rely on double sided sticky tape to secure it.Arrma Infraction/Felony/Limitless ESC Mounting Plate:Screws into the 4 holes in the stock ESC mounting location so you can attach the plate with double sided tape your ESC of choice but making it also removable without having to rip the tape apart and replacing it again each time you remove the ESCHobbywing Push-Button Style Power Button Mount for the Arrma Infraction/Felony/Limitless:Designed to screw on top of the Infraction/Limitless receiver box, makes it removable and no more sticky tape. Works with most Hobbywing 1/8 to 1/5 scale ESCs with the push button style power button and the various rebranded versions as wellArrma Infraction 2-piece Side Skirts (small print bed friendly)A 2-piece side skirt for the Infraction that is small print bed friendlySkyRC GSM-015 GPS Mount for Arrma Infraction:Installs on either the front/rear body mount bar. Recommended install on the rear because the GPS will sit snuggly under the truck bed when the body is mounted preventing it from popping out in case of crash (unless you lose the body, that is)
Arrma Mega/3s/4s Stuff:
Arrma 3s/4s TPU Wing Mount: Remixed version of original design that @jondilly first made, published with his permissionArrma 3s/4s Wing Mount BracingThis is a brace intended for the Arrma wing mount found on the Arrma Mega/BLX 3s Typhon, Outcast 4s, and Kraton 4s (Arrma Part #AR320455). The wing mount often breaks on the rear support strut where the wheelie bar for the 4s trucks usually mount. This brace is made to reinforce the mount to give it more strength .
Arrma Typhon 3s Front Suspension Arms (zero voids)This is a 1:1 clone of the stock Typhon 3s front suspension arms with the only difference being it's a solid arm with no holes in it.SkyRC GSM-015 GPS Case+Mount for Typhon 3sThis case fits the GSM-015 and designed to mount onto the unused front body post holes on the Typhon 3s.Aftermarket ESC mount plates for Arrma 3/4s trucksThis plate allows for easy install/removal of aftermarket ESCs when mounted in Arrma 3/4s trucks instead of pulling off your double sided tape and redoing it all the time.BLX185 ESC Mount for Arrma 3s VehiclesThis adapter plates allows you to shoehorn the larger BLX185 ESC into the Arrma 3s and 4s vehicles. This mount fits on top of the stock receiver box and includes a place to mount the power switch. PLEASE NOTE: This will not work with the Typhon 3s due to it's low profile body (ESCs cannot be mounted on top of the receiver box, there's no room).
Fan/Heatsink Stuff:
Aftermarket Fan Adapters for RC Car ESCs :These fan adapter plates allow you to replace stock ESC fans with a larger sized 30mm or 40mm fan with a higher rpm/cfm for better ESC cooling. The adapters are designed to sit on top of the ESCs without having to remove the ESC cover plate. Adapter Options:- 25mm to 30mm (fits BLX100/120/Max10, etc)- 35mm to 30mm- 35mm to 40mm- 35mm to 40mm w/ embedded M3 nutsArrma Kraton 8s heatsink 30/40mm fan adaptersAllows you to install 2x30mm or 2x40mm fans on the Arrma Kraton 8s Heatsink replacing the stock 50mm fan
Misc Stuff:
Flysky FS-GT5 Radio Upgrades (thumb steering, menu knob replacement, aux channel knob replacements)A few designs I made to improve the Flysky FS-GT5 radio to make it more user friendly, imo. Designs include thumb steering easy add-on, an easier to use menu knob, and Aux5/6 knobs that makes it easy to adjust with 1 finger (works great with Aux6 for rear wheel steer while driving.)RC Wheel Balancer (uses Arrma 6s rear hub assembly)This is a RC wheel balancer I created that basically is a stand and to it you mount an Arrma 6s rear hub with axle/bearings/hexes. With the 6s rear hub you will be able to balance 17mm hex wheels but I've also included adapters that can be quickly mounted so you can balance 12mm hex and 14mm hex wheels.50cal Ammo Box Lipo Organizer TrayEach set of (2) trays is designed to sit in the bottom of a standard military style 50cal ammo box. The total amount of slots for a pair of trays is (8)45x60mm which should fit most 3s-6s RC car sized lipos and (4)28x60mm which fits most 2s RC car sized lipos.RC Body Clip Retainer/Tether Body clip retainer/tether to replace the stock arrma tether. There is another design on Thingiverse that is a closer replica to the stock Arrma tethers but I found it difficult to print because no matter the orientation it needed supports or the results were mixed and quality was meh. I made this as a comparable alternative and it requires zero supports.Hobbymate Speed H6/HOTA H6 Pro Charger Stand:Puts the charger on it's side at a 30% upward angle so you can see the screen from across the room.
Yes it will.That's great. I figured someone had made something like this. I just cut some foam blocks to keep the rocks out. will the Mega steering and driveshaft covers fit the senton 3s BLX? I assume so but wasn't sure if there was a design change. TIA
