- Philadelphia, PA
- Limitless
- Senton 6s
- Talion
- Typhon 6s
- Typhon TLR
I'm going to be starting on a new build soon...just waiting for parts. I want to make an off-road LImitless similar to what Raz Shifrin (video link below) did but with my spin on it. The question I have is does anybody have any experience using the Infraction diffs (15/42 straight cut) for off-road use? I figured these are the fastest diff ratio for on-road cars but would this help an off-road car go faster? Would I loose traction but gain speed? The regular off-road diffs are 10/43 spiral cuts and the Typhon uses 13/43 straight cuts. The 10/43 spirals are proven to be damn near perfect for off-road. At one point I switched the input gear on my TLR Typhon to the 15T Infraction and ran 15/43 but that was for on-road speed (I smoked a few guys with my TLR BTW...LOL) and I was using foam tires. I got the TLR up to 78mph using this setup with 1mil center (46T spur), 500k front and 100K rear. I want to try the Infraction ratio but strictly off-road. Here in Philly 1/5 scale nitro is extremely popular for off road drag racing and I want to compete with that using a 1/7 scale "Limitless type" setup using the fastest gear ratios possible. Is there any advantage/disadvantage to using spiral vs. straight cut off-road? Any thoughts or input would be greatly appreciated.
Link to Raz Shifrin off road build:
He used locked diffs which in my opinion doesn't work well off road since the wheels aren't constantly on the ground like they are on-road. I think you kinda NEED the open diff function for off-road to keep the car balanced over rougher uneven terrain. I also think his build was too narrow and could've benefited from a wider stance (Kraton or Mojave arms). I also think his tire choice could be improved by using a larger diameter to give more ground clearance (I'm thinking belted Katar or even those new Fireteam tires). These are some of the ideas I have to "improve" on his build which I'm definitely borrowing inspiration from. I may even chase the elusive 100mph off-road challenge which I don't think has been done yet.
