Streetsports
- Limitless
- Kraton 8S
You guys probably already know but the limitless spool gears work as pinion gears for the larger motors with 8mm shafts. here's a pic of the 35t. I also modded the motor mount to accept the larger motors and also accept larger gearing. I can probably go up to a 40t now. The aftermarket mount I want is out of stock so I got out the old drill and improvised.
