Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
Go to the hardware store and pick up a stepped drill bit and open that sucker up. I did this on my original motor mount and it looked great. Does a much nicer and cleaner job than a DremelShaft from the motor is too short out of the mount to flip the pinion.
It is similar to the V1 spool in that regard. Just don't like that I have to fool around with spacers, shims and grub screws to mount a pinion on the spool shaft. If they opened up the hole on the slider about 3mm, any size pinion would fit and could be lined up to the og spur location.
Again, the shaft from my TP motor doesn't come out enough to flip the pinion. As for the PPS, mine was destroyed this summer and I'm not planning on buying a new one. The new motor mount in the V2 is huge and designed to be able to hold way wider motors. Want to utilize what's in the kit this time instead of replacing everything on a brand new car.
