V3 Talion replacment tires
Discussion in 'Talion' started by Carmelo, Jul 5, 2018.
  1. Carmelo
    Carmelo Active Member
    Mar 27, 2018
    4
    1
    Arrma RC's:
    Talion
    Hi
    Which tires will be a good replacement for offroad bashing?
    motp4tj1 likes this.
  2. Tjazz13
    Tjazz13 Active Member
    Jun 9, 2018
    3
    1
    Arrma RC's:
    Talion
    Proline Badlands
    servalac likes this.
  3. servalac
    servalac Well-Known Member
    Apr 30, 2018
    116
    129
    Arrma RC's:
    Outcast, Talion
    The original Katar is not a bad tire, but if you wanna upgrade, I would stay around the same diameter, yes the Proline Badlands imo is about the best choice. Proline Shockwave is a little wider but works great too. You gain some side stability by choosing an offset rim. Usually standard on the Proline premounted.
  4. Carmelo
    Mar 27, 2018
    4
    1
    Arrma RC's:
    Talion
    I appreciate your advise. But what about the dboots Backflips?
  5. servalac
    Apr 30, 2018
    116
    129
    Arrma RC's:
    Outcast, Talion
    The Dboots Backflip is a much larger tire, compared to the Katar and Badlands, but why not, there are really no rules :)
  6. servalac
    Apr 30, 2018
    116
    129
    Arrma RC's:
    Outcast, Talion
    Backflips, Badlands, Katar
    RCROD, The_Otherside and Schneider92 like this.
  7. Coopsonthefarm
    Coopsonthefarm Well-Known Member
    Apr 28, 2018
    19
    36
    Kauai
    Arrma RC's:
    Outcast, Talion
  8. Coopsonthefarm
    Apr 28, 2018
    19
    36
    Kauai
    Arrma RC's:
    Outcast, Talion
    Love my Talion with the Backflips! Such a beast!
  9. olds97_lss
    olds97_lss Premium Member!
    Dec 14, 2016
    379
    116
    @op, Do you run 4S or 6S?
    Buddy of mine liked my 3.8" trenchers on my savage flux and got a set for his talion. He geared down the pinion a bit, but it does really well with them. I wouldn't suggest he pin the throttle when in the air, but otherwise they seem to work well.
    I only run 4S on the two trucks I run them on, Savage Flux HP and Traxxas Brushless Revo. Odds are, when I get an outcast, I'll get another set as I really like the tires. They add some decent cushion for the landings and seem to wear well.
  10. Coopsonthefarm
    Apr 28, 2018
    19
    36
    Kauai
    Arrma RC's:
    Outcast, Talion
    I run mostly 6s with stock pinin. With a fan on the motor heat has not been a big issue. The Talion obviously flips way better with these tires and all around beefier off road basher. Love them! All though if I was running on concrete or doing speed runs they would not be my tier of choice.
  11. Piecejointe
    Piecejointe Well-Known Member
    Jul 30, 2017
    204
    84
    Arrma RC's:
    Kraton
    Can you put the badlands on 0 offset rims? I don't want the truck to get wider but having more aggressive tires would be nice.
  12. servalac
    Apr 30, 2018
    116
    129
    Arrma RC's:
    Outcast, Talion
    Sure you can ! Just find some some suitable wheels.
  13. Piecejointe
    Jul 30, 2017
    204
    84
    Arrma RC's:
    Kraton
    Does any exist? Hard to find 3.8 wheels that are not premount. In theory Louise has them but they aren't sold anywhere. Nothing at Proline....
  14. servalac
    Apr 30, 2018
    116
    129
    Arrma RC's:
    Outcast, Talion
    Used to be more unmounted tires/wheels available from Proline, I believe it's all about market/sales.
    Seen people use various rims to fit the Badlands and the 1/2" offset seems to be the most popular, like it myself.
    The Pro-Line 1178-00 is a Traxxas style bead tire, think E-Revo V1, they came on 3.8 17mm hex 0 offset rims, should be easy to find and
    probably for cheap. Just gotta grind away those little tabs inside the hex. I would seriously just go for the pre-mounted ProLine 1178-11 and enjoy the 1/2" offset.
  15. Rpmspeedyblue
    Rpmspeedyblue Well-Known Member
    Feb 11, 2018
    75
    58
    San Jose, Ca
    Arrma RC's:
    Kraton, Outcast
    dboot backflips
  16. RCROD
    RCROD Well-Known Member
    Dec 23, 2017
    538
    179
    Vancouver Island, B.C..
    Arrma RC's:
    Kraton, Talion
    Pro-line Badlands are the perfect tire size for the Talion, and you gotta like that moto-x tread pattern. Yes, you can put Badlands on zero offset rims. You can also stretch the 3.8" Badlands to fit 4.0" wheels, which then allows many choices for wheels. I have some unmounted 3.8 Badlands and DE Racing Speedline Plus 1/8 truggy wheels. I have not glued/mounted them, as still deciding if I will tape them (I'm thinking 2 very thin strips of Gorilla tape for less weight & to keep the center part open for tire venting).
    These DE Racing wheels are the lightest available & weigh only 58g each. Here's the link(s):
    https://www.amainhobbies.com/de-racing-speedline-plus-1-8-truggy-wheel-4-black-der-pt4-8b/p705686
    https://www.amainhobbies.com/prolin...-truck-tires-2-m2-pro1178-00/p387158?v=205632
  17. Piecejointe
    Jul 30, 2017
    204
    84
    Arrma RC's:
    Kraton
    That looks great. I changed the pinion today to make the car a bit faster (15 up from 13) and I'm waiting on these to take it to the next level on our very damaged track: https://www.minicars.se/sv/artiklar/dack-falg-st-viper-1-8-truck-beadlock-svart-2.html
    If this doesn't work I'll follow your steps.
  18. RCROD
    Dec 23, 2017
    538
    179
    Arrma RC's:
    Kraton, Talion
    Although your Arrma RC's only show a Kraton on your Avatar, since you are changing from a 13T to a 15T, and this is the Talion section, I gather you now have a Talion? I'm running a 15T pinion (stock was a 12T) in my 2018 Kraton and no heat issues. I definitely noticed the top end speed has improved greatly. So far I'm very happy with this gearing. I'm putting a 18T in my V3 Talion, and expect very similar results.
    Those tires/wheels look cool for sure. It looks like these are about the same diameter as the Backflips (6.74" tall compared to 6.8") and a good width at 3.2" wide (width is between the 3.0" Backflips and 3.3" Minokawa's). However, if you are putting these on your Talion, this will be a big increase in tire size, 1" taller and 1" wider (as Katar's are only 5.75" tall & 2.24" wide). These might be a better tire for your Kraton, than your Talion, unless you are upgrading to the beefier V3 Kraton hubs?
    Unfortunately, the one negative of beadlock wheels is that they are noticeably heavier, and a heavy wheel is harder on your drivetrain, suspension, heat issues, durability, etc. However, the one positive of a beadlock wheel is you can try different taping methods, if needed & always change it afterwards. Also keep in mind, if you put these much taller tires on your Talion, it will be like putting a bigger pinion in, than the 15T you actually used.
    #18 RCROD, Jul 18, 2018 at 3:36 PM
  19. Piecejointe
    Jul 30, 2017
    204
    84
    Arrma RC's:
    Kraton
    Do the hubs really differ betrween the two? It wasn't the case in the past (V1 at least). Are they even bigger on the Kraton now?
  • Welcome to Arrma Forum
  • Disclaimer
