Dietrich_40
Agreed got Baja tires on my kraton and the hubs have held up well. Was planning to Go the HR route but 6 months in and haven't needed to.
Ye
Yes, the new V3 Kraton rear hubs and steering blocks are beefier and stronger. If you are using a lot bigger and heavier tires and not running 6S and not hitting really big jumps, you might be ok, as some members have not changed to the V3 Kraton hubs, even though they are using much bigger & heavier tires...
I had a look at the hubs and they don't really look stronger, but they are longer (or is it wider?any way, in the direction of the CVD, so more offset) and thus a different shape, but besides the extended part that is supported by extra ribs, the rest looks identical.
Ahhh yes! Are you able to weigh each one? If you can and post the wights thatd be amazing!
Added those to my list/sheet so I can keep track for future tire purchases. Thanks!Backflips (Outcast's stock tires)- 351 grams
Minokawa D-Boots (Kraton's stock tires)- 283 grams
Badlands - 244 grams.
Katar (Talion V3 stock tires): 203g
Louise T-Rock: 257g
Aaaaan the winner is... Louise ST-Viper, at a whopping 458g.
Brand | Tire | Rim Size | Weight (oz) | Grams | lbs |
Traxxas | Maxx AllTerrain (0 offset) | 3.8 | 11.5 | 326.02 | 0.72 |
Traxxas | Talons v1 (0 offset) | 3.8 | 9.1 | 257.98 | 0.57 |
Pro-line | Trencher 3.8 (0 offset) | 3.8 | 13.4 | 379.88 | 0.84 |
Arrma | Backflips (0 offset) | 3.8 | 12.5 | 354.37 | 0.78 |
Arrma | Minokawa Mt (Kraton v3) 1/2" offset | 3.8 | 10.5 | 297.67 | 0.66 |
Arrma | Katar (talion v2/3 stock) | 3.8 | 7.16 | 202.98 | 0.45 |
Louise RC | t-rock | 3.8 | 9.06 | 256.85 | 0.57 |
Louise RC | ST-Viper | 3.8 | 16.15 | 457.84 | 1.01 |
Brand Tire Rim Size Weight (oz) Grams lbs Traxxas Maxx AllTerrain (0 offset) 3.8 11.5 326.02 0.72 Traxxas Talons v1 (0 offset) 3.8 9.1 257.98 0.57 Pro-line Trencher 3.8 (0 offset) 3.8 13.4 379.88 0.84 Arrma Backflips (0 offset) 3.8 12.5 354.37 0.78 Arrma Minokawa Mt (Kraton v3) 1/2" offset 3.8 10.5 297.67 0.66 Arrma Katar (talion v2/3 stock) 3.8 7.16 202.98 0.45 Louise RC t-rock 3.8 9.06 256.85 0.57 Louise RC ST-Viper 3.8 16.15 457.84 1.01
Wonder why the viper's are so heavy. 1/5th scale?
Jeeeez. Nice workAdded those to my list/sheet so I can keep track for future tire purchases. Thanks!
Thanks alot much appreciated! Just purchased katars definitely happyBackflips (Outcast's stock tires)- 351 grams
Louise T-Rock: 257g
